Domain Checks
2314
02-10-2011 04:11 PM
TedCronin
When I setup a domain check at 10 SP1, I am seeing inconsistencies with the checks, for instance I have a few domains in my parcel layer, and only some are getting flagged as having issues where they do not meet the domain rules, such as not being blank, where some that are blank are getting successfully flagged in the same feature class.  This is using batch mode as well.
KumarBhardwaj
I tested the domain check with sample data on Production Mapping 10 SP1 but I am not able to reproduce the issue you reported.
Is this issue specific to some data, can you reproduce this issue with any other data?
MichelleJohnson
Another thing to look at too is if your features have valid subtypes.  If a feature does not have a valid subtype, the domain check will not be able to validate the feature since domains can be defined at the subtype level.
TedCronin
We are checking subtypes, too, but yeah this was a funky issue, not huge for us since we are reviewing at the book level, and I am going through slowly but surely and calcing blanks to NULL just ahead of the Reviewer, this happened to be an area I had not visited.  This was tested on the parcel layer, located here:  http://www.arcgis.com/home/item.html?id=dc09af5412c240d7ac836e81272a8714
I am finding that we do hit scalability issues with the Parcel Poly Domains, but with our Parcel Lines, no issues, in fact I can run the check on the complete dataset.
