Data Reviewer Speed
10270
11
04-01-2015 02:28 PM
AnthonyBarron
This is a multi-part question and I am hoping someone may be able to point me in the right direction. I am working with Data Reviewer 10.2 and I have a Batch Job consisting of Table To Table, Geometry on Geometry, Duplicate Geometry, and Execute SQL checks. The Batch File checks for errors in ~ 375,000 points and ~58,000 Points. My concern is the amount of time required to run the batch file. I'm running my test now and it's been 8 hours with only 209,000 points validated.
My questions are as follows:
1) How can I expedite the batch file?
2) If I run the batch file against "Changed Features Only" will it speed up the results? If so, how does Data Reviewer determine which features have been "Changed"?
SteveSalas
Michelle - just saw this new patch:  Esri Support 10.4.1
Are there any metrics you can share about how much of an improvement this makes?
JonahWaterman
Try and create table index, this will expedite the process. I index all of my tables before batches are run. Hope this helps
