Data Reviewer, donuts and SDE
2472
08-19-2011 09:07 AM
AshleyMott
How does Data Reviewer treat donuts? Is there a difference between the way Data Reviewer reacts to donuts in SDE versus a file GDB?
KumarBhardwaj
Hi Ashley,
I did not see any difference between the way Data Reviewer reacts to donuts in SDE versus a file GDB. I am getting the same results after running a check on feature class with Donut features in SDE and File Geodatabase.
Are you getting different results in File geodatabase and SDE?
AshleyMott
Thanks for the response Kumar. I tested donuts in SDE (SQL) and FGDB and got the same results when checking for "Holes" in a multipart polygon check.
I just worded my question wrong, because I was wondering what checks you would use to look for donuts and if those checks would be different for data in a FGDB vs. SDE (SQL).
I thought that SQL reads/treats the geometry of donuts differently than a file geodatabase.
