Composite Check Window Has White Box Blocking the Screen
3815
5
07-17-2012 11:45 AM
JustinShepard
When trying to create a composite check I can't see the window because of overlapping elements in the dialog. There is a white box that is covering up the input parameters (see screenshot). Is there a fix for this error?
DanHopkins
What version of Data Reviewer are you running?
What service pack level?
What is the OS of the machine?
JustinShepard
ArcGIS Desktop 10.0 sp 4
ArcGIS Data Reviewer 10.0 sp3
What is the OS of the machine? Win 7 64-bit
DanHopkins
What is the display setting on your Windows 7 64-bit machine?
Does this issue occur with any other checks (e.g. Unique ID Check)?
MichelleJohnson
At Service Pack 4 for Data Reviewer, we made a fix to the UIs when your computer's display setting was set to 120 DPI (125%).  However, I would recommend installing the latest Service Pack, SP5, which was just published last week.  Data Reviewer Service Pack 5 also includes the fix for the check dialogs.
JustinShepard
I haven't run a composite check yet but the issue of the white box blocking the elements has been resolved in 10.1.
