Changed Features Only Bug
3770
02-24-2011 12:39 PM
AndrewRudin
Is defect ID 56441 planned to be fixed in 10sp2?  It deals with checking the "Changed Features Only" box when running a check against a feature class on SDE using a two-tier connection.  I noticed it in 9.3.1 and it sounded like it was going to be fixed in 10sp1 but it never was.  This issue is really hindering us from using Data Reviewer to QC versions before they are posted to control, since we have so many checks and a rather large dataset to inspect.  It also prevents us from using the new tools for integrating Data Reviewer into Workflow Manager which we are really excited about.
Here's the Defect info:
Defect ID: 56441
Name: Performance issue encountered on trying to run a batch job on changed features only. This only happens with direct connect
DanHopkins
Andrew,
Thank you for your inquiry into the following defect:
Defect ID: 56441
We have migrated to a new defect tracking system. Defect ID: 56441 is now the following:
Bug: 783
Title: Performance issue encountered on trying to run a batch job on changed features only. This only happens with direct connect
At this time, Bug: 783 is being worked on by the ArcGIS Data Reviewer development team. The tentative planned fix version for Bug: 783 is 10.1.
Regards,
Dan
ArcGISUser
Hmm this is a Data Reviewer check that we will want to explore too.  Please count our vote for also wanting this bug fixed.  We have millions and millions of features, and anything related to performance or degradation of performance is important to us too.
Thank you!
