Zoom to action not available for non hosted data
478
04-03-2026 12:39 PM
MK15
The "Zoom to" action is not available for non hosted data for several of the widgets in dashboards. Are there any workarounds for zooming to the map once a value is selected in a selector element?
@jcarlson @KenBuja @DerekLaw @JenniferAcunto @JohannesLindner
MK15
SteveMarkovick
Known limitation with non-hosted feature layers in Dashboards — the Zoom to action requires the layer to be hosted in AGOL or Enterprise to work natively. A common workaround is using a Data Expression to pull the geometry into a hosted layer context, or setting up a filter action that narrows the map extent instead of a direct zoom. The related thread about Data Expressions and Pan actions linked in that post is probably the most relevant starting point for your specific setup.
