Zoom Action Change?
273
7
3 weeks ago
AnthonyYattoni
Did something change overnight with the Zoom actions for Dashboards?
I have several lists where clicking a record normally zooms into the selected record. Everything was working as expected yesterday, but this morning the functionality has stopped working entirely.
Was there an overnight update that went live and broke this function?
RyanTucker
Seeing the same issue. Nothing zooms to...
Derrick_Westoby
Same here
MatthijsAlberts
Same here. Only pan still works....
AnthonyYattoni
One solution that I found was turning off the pan action. Once I did this, the zoom action worked as expected.
RyanTucker
Thank you for the info!
KateHowlett
I've also found that the 'zoom to selected'  icon on the map does not zoom, it only pans. If I'm too zoomed in it will zoom out so that the selection fills the extent, but if I'm zoomed out it won't zoom in.
Do we think that is related to this issue?
AnthonyYattoni
That is a good question. I'm assuming you are talking about from a pop-up? I wouldn't think it would be directly related, but if you are getting that issue as well, then it very well could be. Sadly, I'm not sure if there is a fix to 'zoom to selected'. I hope this issue is on ESRI's radar.
