View layer field missing from serial chart configure dropdown
821
03-21-2024 05:22 PM
JimMiller3
I have a view layer that is the source for a serial chart in a dashboard.
A column that previously contained NaN values -- labeled 2022_23_chg -- now contains actual numbers. I want to add that column to my chart. I see the column in my view layer table view (screen grab below.)
But that column is missing from the "Add Field" dropdown in the serial chart configure page.
I've tried refreshing and double-checked the view layer settings. As an experiment, I created a new view layer and made a serial chart with that -- the 2022_23_chg field shows up in the configure dropdown. But I prefer to use my existing view layer and not have to re-wire several dashboard elements to a new view layer. And it seems like I shouldn't have to. Thank you for any suggestions.
