Unable to put serial chart categories in correct order
1341
04-21-2025 01:42 PM
JGVadnais1
Hello,
When I create a Dashboard from an existing map, the data categories in a specific field shift.  In the map, the legend listed in sequential order (0 - 20 cm, 20 - 40 cm,  40 - 60 cm  etc...).  As you can see in the attached image, that is not the order in the dashboard.  How does one fix this?
Thank you,
Jenn
clt_cabq
are those the actual field designations your data are in? because they are actually in sorted order for text data, you might try having a field holding an integer value describing the smaller value of each bin like "0" would be for the 0-20cm bin, "100" for the 100-120cm bin, this way they will sort properly as numbers.
JGVadnais1
Bingo!  Thank you for identifying the issue.
