Sort by statistics results cannot access data on serial chart widget
1240
05-28-2024 11:48 PM
Alisha
My organization enterprise just got an upgrade from 10.9.1 to 11.0. Everything went well until I got this issue, I have several ArcGIS Dashboards, each of them have serial chart that went well before, after the upgrade done, the serial chart widget do not display the data. It says cannot access data. I try to config the settings by reselect the data source, it went normal until I do the sort by statistics, there's a warning again saying cannot access data, the field is already an integer.
Soobin-Choi
Hi Alisha, this might be a bug. Can you please contact Esri Technical Support so they can help investigate further?
AlessioDiLorenzo
Same issue here
