Serial chart say "No data" when at Split by field (textbased category) is choosen
510
03-04-2026 05:56 AM
MagneKaspersenAirel
I have used a dashboard for years with no problem. Since last weeks my Serial charts using split by field shows No data. The field used by splitfunction is a textbased field with using domain. Any suggestions why?
SandraLuken1
Sorry to hear that you are running into changes in your dashboard since the update last week. We would suggest reaching out to Esri Technical Support as they will better able to assist with the troubleshooting and confirm if this is related to the update.
LJackson29
@SandraLuken1
I am also experiencing this in a ArcGIS Online dashboard that I am creating using an enterprise portal service. The primary field (Structural Condition Rating) is an integer that I am treating like categories (1,2,3,4,5) , and my split field (Asset Class) is a text field. The chart is fine when I just have the the structural condition rating, it shows the counts for each condition rating value (see below), but when I try to split it by Asset Class, I get "No data". Am I doing something wrong, or is this a bug?
Many thanks 🙂
No split
Adding Split
LJackson29
@SandraLuken1 I am still experiencing this issue, has it been logged as an official bug? When I create a data expression and use the data from there I am able to create the chart as expected; however that is not an option for this dashboard.
