Selector for Categorical Variable Choropleth Map
761
02-05-2024 01:40 PM
Ed_
by MVP Regular Contributor
Based on the sample data below is it possible to plug the `Category` column in a selector? From the selector, the user can select a variable and based off of that Dashboard will automatically update the Choropleth Map.
I know this is possible in Insights but was wondering if this could be done in Dashboards.
And if that's not possible then is it possible after I first pivot wide the data that is have dedicated columns  for each categorical variable `A`, `B` and `C`, the user can pick a categorical variable column and based on selected column, the choropleth map will update accordingly?
Sample data:
Location	Category	Value
1	        A	        1
2	        A	        2
3	        A	        3
4	        A	        4
1	        B	        5
2	        B	        6
3	        B	        7
4	        B	        8
1	        C 	        9
2	        C	        10
3	        C	        11
4	        C	        12
Question | Analyze | Visualize
