Pop-ups not displaying properly
547
06-23-2026 05:50 AM
KassieKM
I have some pop-ups not displaying properly in a dashboard. They look great in map viewer, but in the dashboard the graphic bar is squished. Images below. I did not code this pop up, it comes from ESRI. We used the Calculate Composite Index Tool and with the output you get a nicely designed popup. I will say this level of arcade coding is over my head. I poked around a bit and tried to change some of the code that I thought affected the width of the bar chart, but no dice. I've attached the code below as well. Any suggestions?
Thanks!
Arcade code below
var outIndexFields = [
    { value: $feature.INDEX_,
    alias: "INDEX",
min: 0.0, max: 0.7181205679375883,
comparison: 0.19113439224444234},
{ value: $feature.INDEX_RANK,
alias: "Index - Mean (Rank)",
max: 416},
var inVariableFields = [
{ value: $feature.Perc_HH_NoVehicle_PREPROCESSED,
alias: "Percent of Housholds with No Vehicle (Min-max)",
min: 0.0, max: 1.0,
comparison: 0.07396450933711171 }
, { value: $feature.PercHH_Poverty_PREPROCESSED,
alias: "Percent of Housholds with Income Below the Poverty Level (Min-max)",
min: 0.0, max: 1.0,
comparison: 0.17998483537835877 }
, { value: $feature.Perc_HH_Disability_PREPROCESSED,
alias: "Percent of Housholds with 1 or more Persons with a Disabilty (Min-max)",
min: 0.0, max: 1.0,
comparison: 0.3194538320178566 }
var indexInfo = { name: "Composite Index" , preprocessing_method: "MINMAX", combination_method: "MEAN", removeMeanLine:"FALSE" };
var finalMessage = " ";
var rankLabel = "Rank:";
var inputVariablesLabel = "Input Variables";
var comparisonTextforPopup = "Average";
// Constants and functions
var nameCharLimit = 100;
var htmlBreak = "<br>";
var htmlSpan = "</span>";
var margin = "&ensp;";
function borderLeftFnc(size, color){
    return "border-left: "+size+"px solid "+color+";";
function borderRightFnc(size, color){
    if (size < 2) {
        return "border-right: 0px solid "+color+";";}
    else{
        return "border-right: "+size+"px solid black;";
function borderTopBotton(size){
    return "border-top: 1px solid grey;border-bottom: 1px solid grey;";
function styleCell(typeOfCell, colorCell, width, height, borderLeftSize , borderRightSize){
    var borderColor="grey"
    var round = 5;
    var roundleft = "border-left:1px solid gray;border-top-left-radius:"+round+"px;border-bottom-left-radius:"+round+"px;";
    var roundright = "border-right:1px solid gray;border-top-right-radius:"+round+"px;border-bottom-right-radius:"+round+"px;";
    var background = "background-color:"+colorCell+";";
    var widthHeight = "height:"+height+"; width:"+width+"%;";
    var styleValue = "";
    var startTD ="<td style='";
    var endTD = "'></td>";
    if (typeOfCell == "left")
         return startTD+roundleft+background+borderTopBotton(1)+borderRightFnc(borderRightSize,borderColor)+widthHeight+endTD;
    if (typeOfCell == "center")
        return startTD+background+borderLeftFnc(borderLeftSize,borderColor)+borderTopBotton(1)+borderRightFnc(borderRightSize,borderColor)+widthHeight+endTD;
    if (typeOfCell == "right")
        return startTD+roundright+background+borderTopBotton(1)+borderLeftFnc(borderLeftSize, borderColor)+widthHeight+endTD;
    if (typeOfCell == "complete")
        return startTD+roundleft+background+borderTopBotton(1)+widthHeight+roundright+endTD;
function buildVariableBar(hexValueC, min, max, mean, val, barHeight, removeLine, fontSize){
    var barHeight = Text(barHeight)+"px";
    var widthLeft = 5;
    var widthRight = 5;
    var barLabelWidthLeft = Text(widthLeft)+"%";
    var barLabelWidthRight = Text(widthRight)+"%";
    var range = max-min;
    var minLabel = Text(Round(Number(min),3));
    var maxLabel = Text(Round(Number(max),3));
    var styleLabelCell = "background-color:transparent;border: 0px;height:"+barHeight+";width:"+barLabelWidthLeft+";";
    var startCell = '<td style="'+styleLabelCell+' text-align: right;padding-right: 5px;">'+minLabel+'</td>';
    var endCell = '<td style="'+styleLabelCell+' text-align: left;padding-left: 5px;">'+maxLabel+'</td>';
    var figure = '<figure class="table"><table style="border-spacing:0px;margin-left:20px;margin-right:20px;margin-top:5px;margin-bottom:5px;'+fontSize+'"><tbody><tr><th></th>';
    var endFigure = '</tr></tbody></table></figure>';
    var proportionWidth = 100;
    var hexv = "#"+hexValueC;
    var hexValueColors = [hexv,hexv,hexv];
    var widths = [0,0,0];
    var borderLeft = [0,0,0];
    var borderRight = [0,0,0];
    var typeOfCell = [];
    var valProportion = (val-min)/range;
    var meanProportion = (mean-min)/range;
    var meanValProportion = Abs((mean-val)/range);
    var emptyMeanProportion = (max-mean)/range;
    var emptyvalueProportion = (max-val)/range;
    if (val == min) {
        if (removeLine)
            hexValueColors[0]="transparent";
            widths[0] = proportionWidth;
            typeOfCell = ["complete"];
        else
            hexValueColors[0] = "transparent";
            hexValueColors[1] = "transparent";
            widths[0] = meanProportion*proportionWidth;
            widths[1] =(1 - meanProportion)*proportionWidth;
            borderRight[0] = 2;
            typeOfCell = ["left", "right"];
    else if (val == max){
        if (removeLine)
        else
            borderRight[0] = 2;
    else if (val == mean){
        widths[0] = valProportion*proportionWidth;
        widths[1] =(1 - valProportion)*proportionWidth;
        if (!removeLine)
            borderRight[0] = 2;
    else if (val < mean) {
        if (removeLine)
        else
            typeOfCell = ["left", "center","right"];
            widths[1] = meanValProportion*proportionWidth;
            widths[2] = emptyMeanProportion*proportionWidth;
            hexValueColors[1] ="transparent";
            hexValueColors[2] ="transparent";
            borderRight[1] = 2;
    else if (val > mean)
        if (removeLine)
        else
        {   typeOfCell = ["left", "center", "right"];
            widths[2] = (1-valProportion)*proportionWidth;
            borderRight[0] = 2;
            borderLeft[1] = 0;
    var temp = "";
    for(var i = 0; i < Count(typeOfCell); i++)
         temp = temp + styleCell(typeOfCell[i], hexValueColors[i], widths[i], barHeight, borderLeft[i], borderRight[i]);
    return figure+startCell+temp+endCell+endFigure;
// Function to get quartiles from a provided range
function getQuartiles(minval, maxval){
      var range = maxval - minval;
      var quartileval = range / 4;
      var firstQuartile = minval+quartileval;
      var secondQuartile = firstQuartile+quartileval;
      var thirdQuartile = secondQuartile+quartileval;
      var fourthQuartile = thirdQuartile+quartileval;
      return [firstQuartile, secondQuartile, thirdQuartile, fourthQuartile];
function calculateQuantiles(minValue, maxValue, numQuantiles) {
    // Generate an array of values from minValue to maxValue
    var data = [];
    for (var i = 0; i < numQuantiles; i++) {
        var quantileValue = minValue + (i / (numQuantiles - 1)) * (maxValue - minValue);
        data[i] = quantileValue;
    return data;
// Function to get the color scheme based on the value
function calcIndexHex(value, quantiles){
    var hexValue = when(value < quantiles[0], "F7FCFD",
                        value >= quantiles[0] && value < quantiles[1], "E0ECF4",
                        value >= quantiles[1] && value < quantiles[2], "BFD3E6",
                        value >= quantiles[2] && value < quantiles[3], "9EBCDA",
                        value >= quantiles[3] && value < quantiles[4], "8C96C6",
                        value >= quantiles[4] && value < quantiles[5], "8C6BB1",
                        value >= quantiles[5] && value < quantiles[6], "88419D",
                        value >= quantiles[6] && value < quantiles[7], "810F7C",
                        value >= quantiles[7], "4D004B",
                        "N/A")
    return hexValue
function createPopup(indexArray, variablesArray, indexInfoArray, messages){
    var popupHTML = ""
    // # Pop-up Section 1: Index value information
    var overallIndexValue = Round((indexArray[0].value), 2);
    var overallIndexHex = calcIndexHex(overallIndexValue, calculateQuantiles(indexArray[0].min, indexArray[0].max, 9));
    // ## Line 1: Index Title
    if (indexInfoArray.name == ""){
        var indexTitle =  "Composite Index: "+Text(overallIndexValue);
    } else {
        var indexTitle = indexInfoArray.name+": "+Text(overallIndexValue);
    var removeLine = indexInfoArray.removeMeanLine == "TRUE";
    // ## Line 2: Index rank
    var indexRankText = messages[1] + " "+ indexArray[1].value + " / " + indexArray[1].max;
     // ## Line 3: Bar to represent index value visually
    var indexBox = buildVariableBar(overallIndexHex, indexArray[0].min, indexArray[0].max, indexArray[0].comparison, indexArray[0].value, 30, false, "");
    // ## Assemble html for pop-up section 1
    var popupSection1HTML = '<h2><span>' + indexTitle + htmlSpan + htmlBreak + '<span style="font-size:12px">' + indexRankText + htmlSpan + htmlBreak +
        '<span style="font-size:14px">'+ indexBox + htmlBreak + htmlSpan + '<span style="font-size:18px">'+messages[2]+htmlSpan+"</h2>";
    // # Pop-up Section 2: Explanatory variable information, Iterate on input fields - each field will have three lines: (1) Title, (2) Value
    var variablesHTML = "";
    var variableCount = 0;
    for(var x in variablesArray){
        // Get the needed data to assemble the lines for the variable
        var alias = variablesArray[x].alias;
        var val = Round(variablesArray[x].value, 3);
        var comp = Round(variablesArray[x].comparison, 3);
        var hex = "C1C1C1"
        // ## Line 1: Variable Title
        if (Count(alias) > nameCharLimit){var alias = Left(alias, nameCharLimit) + "... ";}
        var popupSection2Line1 = margin +'<span style="font-size:12px; word-wrap: break-word">'+ "<strong>" + alias + "</strong>"+htmlSpan;
        var popupSection2HTML = popupSection2Line1;
        var variableNameHTML = popupSection2HTML;
        var variableBarHTML = buildVariableBar(hex, variablesArray[x].min, variablesArray[x].max, variablesArray[x].comparison, variablesArray[x].value, 20, removeLine, "font-size:13px;");
        variablesHTML += variableNameHTML + htmlBreak + variableBarHTML;
        variableCount += 1;
    // # Pop-up Section 3: Index design information, Line 1: Sentence about how the index was created.
    var popupSection3HTML = '<span style="font-size:12px;">'+messages[0]+'</span>';
    // Final section: Logic to assemble the popup
    popupHTML += popupSection1HTML;
    popupHTML += variablesHTML;
    popupHTML += popupSection3HTML;
    return popupHTML;
var txt = createPopup(outIndexFields, inVariableFields, indexInfo, [finalMessage, rankLabel, inputVariablesLabel]);
return { type:'text', text:txt}
KassieKM
I turned to chatgpt and found the culprit!
I changed these lines of code:
To...
var figure = '<table style="width:100%;border-spacing:0px;margin:5px 0px;'+fontSize+'"><tbody><tr>';
var endFigure = '</tr></tbody></table>';
And now all works well!
Laura
by MVP Regular Contributor
As far as the color of it goes - that is most likely due to the theme of your dashboard. For size try looking at the different length settings in the code. For example
    var widthLeft = 5;
    var widthRight = 5;
Try making this number larger and seeing the effect in dashboards.
KassieKM
Thanks for the suggestion. I tried it and unfortunately it only affects where the bar starts, not the length of the bar.
Laura
Maybe where it says Margin left & right reduce to 0 px rather than 20 px.
KassieKM
Nope, nothing. Thanks again for the suggestions!
KassieKM
To...
