Performance Issues
124
3 weeks ago
jvarasanz
Good morning.
Our users are reporting issues with dashboard performance. It looks like the search tool in the list, once the user tries to type something, freezes the dashboard and they are no longer able to interact with it. This list widget is using Arcade expressions that refresh at a 0.1 min interval. The data source is a layer from the map widget that refreshes every minute. The layer is not editable and not shared publicly, but its cache control is set to 1 minute.
The behavior described applies to both edit and view modes.
Please note we use this dashboard for emergency response, so we'd appreciate any response and whether this is unique to our use case or if there is a bug that has been recorded to resolve the issue.
Kind regards.
ShaneONeill_144
  • Approximately how many records are displayed in the list, and how many Arcade expressions are configured
  • Does the freeze still occur if you disable the list's Arcade formatting temporarily?
  • Does changing the refresh interval from 0.1 min to 1 min help with the issue?
  • What is the source of the data, a Hosted feature layer or a Map/Feature service from Enterprise?
