Maximum Suggestions in Web Map
1217
08-21-2023 02:31 PM
FayGlunt
Hi, Dashboard and Web Map Gurus.  We have enabled search in the settings of Web Map we are using in our dashboard, so our users can search on work order, notification number, asset number and address.  If we have 9 job locations for a given work order, when we search using that work order number, it only suggests 6 of the 9.  Is there a way to increase the maximum in the Web Map to make it more than 6?
I found this:
https://support.esri.com/en-us/knowledge-base/problem-the-arcgis-online-map-viewer-search-tool-retur...
Does this mean we need to convert our dashboard to a web appbuilder app?
AndreasHall
I think the easiest way to solve this is to abandon the search functionality in the map widget and instead add a category selector, with search enabled, to your dashboard. You can configure how many matching results the selector should show when performing a search.
Use selectors—ArcGIS Dashboards | Documentation
AndreasHall
