Make Chart Unselectable in ArcGIS Dashboards
838
02-06-2025 07:58 AM
apgis16
I have a chart using a data expression and I don't have any actions on it for other elements on the dashboard. Is there a way that I can make it so the user cannot select sections of the chart and only hover to see the values?
JanetBrewster1
@apgis16 If you have a chart with no Actions, then a user should not be able to select any part of the chart. And as long as you have "Hover Text" turned on (under "Series"), the users will be able to see values.
Are you seeing otherwise?
Janet
JanetBrewster1
Janet
