Linking multiple indicator widgets
1462
05-14-2021 06:32 AM
JLiepins
I am working on a dashboard which has multiple indicators linked to a feature in the map. There is a selector which allows multiple items to be selected. Each indicator is populated with the correct field info, and sorted properly. What I am wondering is if there is a way to link them all, so that when I click an arrow at the top to go to the next selected record/item, the rest of the indicators also move to the next selected record/item. Right now we have to go through each indicator (there are a lot of them) and click the arrow button on the top of each one to go to the next record for each indicator widget.
Is there a way to set a featureset in arcade and link the indicators to that featureset?
Can the python API connect to a pre-existing dashboard and make changes to the widgets?
 Is there another option that I might be missing?
Thank you in advance for your help.
DavidPike
MVP Notable Contributor
Hi, Would you be able to provide some screenshots etc. as I can't really picture the setup.
