Lasso Tool on Dashboard filters widget
158
a week ago
ONeilkaBacchus
So I'm trying to use the lasso tool to filter 2 different layers on the map. These layers have a combine count of the total records displayed as an indicator.
For context: I have 2 feature layers embedded on the map. they have identical fields. I don't want to combine all the records into one feature layer (risk breaking other apps), so instead i did an arcade expression on an indicator to do a total count of the records from the feature layers. However, when i use the lasso tool to filter the records, only one layer is affected in the indicator.
Is there another work around for this rather than combing the records into one feature layer?
Thanks!
Neal_t_k
MVP Regular Contributor
I think you could try, instead of using arcade, you could turn on the Reference in the indicator, set one FS as the source for datapoint and the other as the source for reference and then use the advance settings to add and display the results?
