June 2026 Update Lost Functionality
The category selector in ArcGIS dashboard single selection no longer supports a default selection unless it is set to "Required selection".
I need to have an ArcGIS Dashboard filter default to a selection but allow the user to see all.
This is important for many cases. One example is open support tickets. If you want to set the default for the dashboard to only show open tickets but allow for the user to also see all, that is not possible.
No Default selection option when "Require selection" is toggled off
Default selection when "Required selection" is toggled on:
I have the same issue. WHY WAS THIS REMOVED???? I have filters setup on my fire calls dashboard that no longer work. Please restore this to the way it worked before the June update.
