I'd like to know if it's possible to interact with the map on the 2 features classes after a featureSet was created. I explain: I got lines and information terminal. On this fc, there is a field called "Lines" with the names of lines separated by /. I can create a featureSet with the name of the terminal and the lines
My goal is to interact on each layer on the map. When I try, it's impossible. With one, it's ok but not with the both.
Here OK.
Here NOK because the tool gives me the same field above.
So, is there a way to do that or not?
Thank you!!
