How would I scroll through elements in an ArcGIS Online Dashboard?
1914
03-25-2020 07:48 AM
RonaldSheaks
I'm building an ArcGIS Online Dashboard and I have 99! indicators for each of the counties in the state. Is there a way that I can scroll down through the 99! indicators? Otherwise I will have many small 99! indicators on the edge of the dashboard.
I would like direction as to how this would be accomplished and the correct tools to use. I am not against minor programming to accomplish this.
Thanks.
BenTurrell
Hey Ronald Sheaks‌,
ArcGIS Dashboards allows you to stack the widgets. You can see an example of this here:
Operations Dashboard for ArcGIS
I've attached a short video as it was easier than trying to explain it!
Ben
If this answer was helpful please mark it as helpful. If this answer solved your question please mark it as the answer to help others who have the same question.
