How to add Dynamic Dates to indicators and Serial charts
426
03-13-2026 04:28 AM
Brett_Adie
Good day
I have set up a number of Indicators and Serial Charts as well as setting up a Date Selector. I would like to add the dates chosen in the Date Selector to the Indicators and Serial Charts as part of their title/heading. SO for example an Indicator should have a Title of "Average Aluminum (ug/L) Results over (date from selector)".
1) is this possible, if so how would i go about doing it
2) would it be better to have the title as part of a separate Rich Text element, if so how would i add the date range to it?
3) also would it be possible to change the date format to South African/English (eg DD MM YYYY or YYYY MM DD)
kind regards
SteveMarkovick
Never thought something like showing selected dates in titles would be such a workaround-heavy task. You set up filters, everything updates nicely, but the titles just stay static and break the whole context. Ended up digging through Arcade and still felt limited. Kinda surprising for dashboards that are otherwise pretty flexible and user-friendly
