how can reflect Coordinates into Operations Dashboard as road line feature?
1183
06-25-2018 10:11 PM
GamalMohamed_Nasr_Eldin
 I have excel sheet with coordinate prepared for Operations Dashboard for roads status, how can reflect Coordinates into Operations Dashboard as road line feature, not as points?
DerekLaw
Esri Esteemed Contributor
Hi Gamal,
If I am interpreting your question correctly, it looks like you have linear referenced data. You will have to publish the data as a linear referencing service with Esri Roads and Highways for Server.
Enabling the linear referencing capability—Event Editor for Roads and Highways | ArcGIS Enterprise
Once the data is available as a map service, then Ops Dashboard can access the data. Although I am not sure if its elements can display the linear referencing data content in its charts.
Hope this helps,
Many Thanks, Mr. Derek Law
I will try it.
