Filtering List by Map View
1005
06-06-2022 10:15 AM
LoganBolan1
Hi!,
I am building a dashboard where I have a list, and the list is connected to a layer on the map. I want the list to autofilter based on the current view to show only the projects in the current mapview. How can I link the list to the mapview?
Logan
Tags (3)
RobertBorchert
Honored Contributor
With your dashboard in Edit Mode then select the Configure for your map.
Select map actions
When map extent changes
Filter
then select your targets
However, you may find people don't use this as much as you may think they will and get frustrated by having to constantly zoom back out
