Enable subscriber content on a web map embedded in a dashboard
694
12-12-2024 01:56 PM
rwrenner_abtglobal
I'm trying to enable subscriber content in ArcGIS Dashboards (or the publicly shared web map on which those layers exist, embedded in the dashboard), as my publicly shared dashboard is still making people log in to view:
Warning seen on the map, and when I click 'review sharing' it does not give me any option to click 'update sharing' because the problem layers are subscriber content, thus I don't have 'permission to update':
I see guidance on how to enable subscriber content in this blog article, however, I do not see this option in the current configuration settings. Am I looking in the wrong place, or has the method to change this setting moved?
What the blog shows:
vs the options I'm seeing:
(Not sure if relevant, but I also see in the same blog: "You can’t authorize subscriber content in Map Viewer... for public use." Does this mean I can't have a public dashboard that contains subscriber content originating from the map widget? Otherwise, I'm not sure how to interpret this.)
-Rylee
