Dashboard grafico
1186
04-04-2020 02:41 PM
Carlos_AndresCamacho_Acuña
En Operations Dashboard for ArcGIS, al utilizar el gráfico de serie, existe alguna manera de graficar por fechas cuantas encuestas se han realizado, pero que el valor sea acumulativo,
Ejemplo
El 2/2/2020 tenía 2 encuestas
El 5/2/2020 tenía 5 encuestas que serían las dos anteriores más 3 nuevas
DerekLaw
Esri Esteemed Contributor
Hi Carlos,
I used Google translate to understand your question,
> In Operations Dashboard for ArcGIS, when using the serial graph, there is some way to graph by date how many surveys have been conducted, but the value is cumulative,
Example:
- 2/2/2020 had 2 surveys
- On 2/5/2020 it had 5 surveys that would be the previous two plus 3 new ones
Please see my reply on this other similar topic thread,
https://community.esri.com/thread/250675-esri-dashboard-create-cumulative-chart
Hope this helps,
