I need to add all the numbers in one field to get a total. I dont see where I can do that. It only does an occurrence count.
example
interactions
Need my dashboard count to show 12 for adding all the numbers from field interactions not that there were 3 occurrences
How are you trying to display this count? In a chart? In a gauge? Please elaborate on the question and give as much detail as possible.
I am using an indicator
Use the 'Sum' statistic method.
When I select SUM I get a "No data" on my indicator
Is the data field that you are trying to summarize Numeric?
Hi Michael
Is there a way to get the sum of the numbers inside the field?
Did you try using Developer Tools in the web browser to see if any errors were being thrown?
I asked if it was numeric as you can store numbers in a text field, so it would appear on the surface to be a numeric field.
What kind of numeric field are you using (short integer, long integer, float)?
I am using long integer
