Dashboard Category Selector
2874
08-15-2019 11:07 AM
CynthiaKozma
I am trying to add a Category Selector to an Operations Dashboard so the public is able to Search on a Parcel Number.  This database is quite large with 100,000 records and it seems to only search the first so many of the feature layer.  Is there a record limit to the selector?  If I put in a number that doesn't show up in the viewing list, it tells me that there are no matching options.
Any help would be great!  Thanks!
SuddhaGraves
In your Selector Options you should have a Maximum Features Displayed field.  Did you try to set this value to your total number of records (e.g. 100,000)?
CynthiaKozma
So, I tried that and it really slowed the application down - pretty much to the point of being unresponsive most of the time.  I decided to put it in the Search of the map instead.  It isn't in the preferred place, but it works and it is fast.  Thank you for your help.
