Creating Embedded content linked to survey123 form through ArcGIS REST or Python API
884
04-06-2023 03:31 PM
mattkramer
Hello, I am trying to create a dashboard from scratch using just the API. I need this dashboard to have an embedded content that links a layer in a map to a survey form that can be selected from a list. So far, we have been able to create all the elements we need to (Map, List, Survey123 Embedded content) but we have been having trouble getting the Embedded Content to use the globalID of the feature layer to filter the survey results. From looking at the item link of some existing dashboards, I have found that these embedded content elements have a "datasets" property that seems to contain the definition of the element that controls this functionality, here is that snip:
"datasets": [
          "type": "serviceDataset",
          "name": "main",
          "dataSource": {
            "type": "layerDataSource",
            "layerId": "1873e4024fb-layer-3",
            "ownerId": "676b5e65-a26c-4c06-ad74-b9c80607c802"
          "groupByFields": [],
          "orderByFields": [],
          "statisticDefinitions": [],
          "maxFeatures": 1,
          "clientSideStatistics": false,
          "outFields": [
          "returnDistinctValues": false,
          "allowDownload": false
      "type": "embeddedContentWidget",
Also included the "type" field just for context. Is there any way to edit this property through script? The whole dashboard is being created from scratch so the ids of the elements should be able to be accessed without too much trouble. If this is able to be changed, how would we go about finding the "layerId" field as well? That does not look like something I have seen before.
