Can You Print Dashboard Poster Sized?
2426
08-14-2023 01:43 PM
GIS_Fox
Good afternoon dashboards users,
I was curious if anyone had any experience or success downloading, printing, or converting a web based dashboard page to a poster size PDF or Word Doc such as at Arch D 24"x36" or larger? Taking a screenshot may be fine but I wanted to see if there were any more professional or high res alternatives to a jpeg screenshot. High density blooms don't look as stunning or accurate with low res screenclips without having to go and convert the data to a PRO or ArcMAP project layout sized large enough.
For example, take a dashboard that you need a screenshot, data point, or saved moment from and you want to print it to a poster with good resolution either directly out of the browser or via screen capture and bring it to a meeting to show in tandem with the live web app as a result of the density or importance of the data being shown to multiple stakeholders. There are times when small 11x17 handouts aren't enough and the internet may go out so mid-presentation so having physical backups on hand or for record with good enough quality may help.
There's a dozen or more dashboard print ideas posted already but if anyone's had success so far with this method I'm interested in reading into it or trying myself.
Cheers!
Jansen Lyons - Records and GIS Section - Public Works - City of Rio Rancho, NM
JRhodes
Hi Jansen, this might work for your purposes:
1. Open the dashboard in Chrome/Edge and press CTRL-SHIFT-I to open developer tools.
2. Press CTRL-SHIFT-M to toggle on device emulation.
3. Make sure Dimensions: Responsive is selected at the top of the window, then enter an appropriate resolution. 3000x2000 seems to give a good resolution for a 36x24, but you can experiment.
4. Select DPR: 3.0:
5. Click the three dots and select Capture Full Size Screenshot:
Wait a few moments and Chrome/Edge will create a PNG in your downloads.
JRhodes
4. Select DPR: 3.0:
JessicaMcCann
You may want to look at this trick with Experience Builder and maybe it could help.
Printing from ArcGIS Dashboards? Let me show you how to do it (Blog)
https://esri.lightning.force.com/lightning/r/Knowledge__kav/ka15x0000008nFTAAY/view
