Bringing select_multiple questions from Survey123 into ArcGIS Dashboards
1320
03-16-2025 02:02 PM
luisadesgranges
I was wondering if it's possible to represent Survey123 select_multiple questions in ArcGIS Dashboards other than as indicators......I had a question where people needed to select some themes but they were able to select more than one at the same time in a select_multiple field. Now I wanna represent that in graphs but when I select that field in the dash, I wasn't able to make it count the values individually. Each answer is divided by comma and even if the same themes were selected but in different orders they are read as different answers.
Does anyone know a way to work easily with those values? Workarounds are also welcome!
Thanks a lot,
xy
TL2
You can use an arcade expression to break the multiselect apart and group by type.
luisadesgranges
Do you have an example of one of those expressions? And will the filters still work normally?
