ArcGIS Dashboards- Sidebar Issue- Description Text Removes Filters
1287
09-19-2023 12:35 PM
Amanda__Huber
MVP Regular Contributor
Hello Dashboard Team,
We recently ran into an issue with the sidebar widget in ArcGIS Dashboards.
When the a lengthy amount of description text is added, the predefined filters dissapper.
Here are the filters we have:
but when this text is added, the filters disappear (see red line):
Once the text has been added there is no way to edit or manage these filters either, even when clicking on them from the side panel:
Please advise, thanks so much
- Amanda Huber
---UPDATE---
After a little more digging it appears the Description portion of the sidebar window squishes out the filter section in the backend code. The Filter's scrollbar area also disappears. I believe this issue could be resolved if both the Description section and the Filter sections of the Sidebar had their own scrollbars.
EllieHakariAK
Hello @Amanda__Huber!
I regularly need lots of space for text in my dashboards, so I understand your pain! As long as there are only a couple filters, you can move them to the header and use the sidebar solely for text, like this:
Hope this helps!
