ArcGIS Dashboards Arcade Data Expression not working after update
5901
15
11-13-2024 06:45 AM
LJackson29
Hello -
I am working in ArcGIS Dashboards and have a data expression that is no longer working after the update last night. I am getting this error "Test execution error: layerId=1 provided for Map Service item. Verify test data." It is not clear what this error is - the layerid is correct. I am using a map image service pulled in from Enterprise Portal that has 3 layers. See my code below.
var port = Portal('https://www.arcgis.com');
var fs = filter(FeatureSetByPortalItem(
  port,'xxxxxxxxxxxxxxxx', 1,
  ['PH_PROJECTID', 'PH_PHASEID', 'PH_PHASENAME', 'PH_COMPLDATE', 'PH_STATUS', 'PH_PHASETYPE', 'PH_STREAMRESTORED_LFT', 'PH_WETLAND_AC', 'PH_FLOODPLAIN_AC', 'PH_CULVERTREPAIRED_FT', 'PH_SEDIMENTREMOVED_CY', 'PH_BASINSTORAGE_ACFT', 'PH_TREESPLANTED', 'PH_WAC', 'PH_SUBWATERSHED', 'PH_COMMUNITY1'],
  false),
  "PH_STATUS='07. Completed' AND (PH_PHASETYPE='1. DesCon' OR PH_PHASETYPE='2. SWIM' OR PH_PHASETYPE='3. Partner' OR PH_PHASETYPE='4. Parcel Acquisition')"
var out_dict = {
    fields: [
        {name: 'projectid', type: 'esriFieldTypeString'},
        {name: 'phaseid', type: 'esriFieldTypeString'},
        {name: 'phasename', type: 'esriFieldTypeString'},
        {name: 'phasetype', type: 'esriFieldTypeString'},
        {name: 'complyear', type: 'esriFieldTypeString'},
        {name: 'status', type: 'esriFieldTypeString'},
        {name: 'stream', type: 'esriFieldTypeDouble'},
        {name: 'wetland', type: 'esriFieldTypeDouble'},
        {name: 'floodplain', type: 'esriFieldTypeDouble'},
        {name: 'culvert', type: 'esriFieldTypeDouble'},
        {name: 'sediment', type: 'esriFieldTypeDouble'},
        {name: 'basin', type: 'esriFieldTypeDouble'},
        {name: 'trees', type: 'esriFieldTypeInteger'},
        {name: 'wac', type: 'esriFieldTypeString'},
        {name: 'subwatershed', type: 'esriFieldTypeString'},
        {name: 'community1', type: 'esriFieldTypeString'},
        {name: 'streamcat', type: 'esriFieldTypeString'},
        {name: 'wetlandcat', type: 'esriFieldTypeString'},
        {name: 'floodplcat', type: 'esriFieldTypeString'},
        {name: 'culvertcat', type: 'esriFieldTypeString'},
        {name: 'sedimentcat', type: 'esriFieldTypeString'},
        {name: 'basincat', type: 'esriFieldTypeString'},
        {name: 'treescat', type: 'esriFieldTypeString'},
    geometryType: '',
    features: []
// Iterate over each feature in the layer
for (var f in fs){
    Push(
        out_dict['features'],
        {attributes:
                projectid: Text(f['PH_PROJECTID']),
                phaseid: Text(f['PH_PHASEID']),
                phasename: Text(f['PH_PHASENAME']),
                phasetype: Text(f['PH_PHASETYPE']),
                complyear: Year(f['PH_COMPLDATE']),
                status: Text(f['PH_STATUS']),
                stream: Number(f['PH_STREAMRESTORED_LFT']),
                wetland: Number(f['PH_WETLAND_AC']),
                floodplain: Number(f['PH_FLOODPLAIN_AC']),
                culvert: Number(f['PH_CULVERTREPAIRED_FT']),
                sediment: Number(f['PH_SEDIMENTREMOVED_CY']),
                basin: Number(f['PH_BASINSTORAGE_ACFT']),
                trees: Number(f['PH_TREESPLANTED']),
                wac: Text(f['PH_WAC']),
                subwatershed: Text(f['PH_SUBWATERSHED']),
                community1: Text(f['PH_COMMUNITY1']),
                streamcat: IIF(f['PH_STREAMRESTORED_LFT']>0, 'Yes', 'No'),
                wetlandcat: IIf(f['PH_WETLAND_AC']>0, 'Yes', 'No'),
                floodplcat: IIf(f['PH_FLOODPLAIN_AC']>0, 'Yes', 'No'),
                culvertcat: IIf(f['PH_CULVERTREPAIRED_FT']>0, 'Yes', 'No'),
                sedimentcat: IIf(f['PH_SEDIMENTREMOVED_CY']>0, 'Yes', 'No'),
                basincat: IIf(f['PH_BASINSTORAGE_ACFT']>0, 'Yes', 'No'),
                treescat: IIf(f['PH_TREESPLANTED']>0, 'Yes', 'No'),
//Return populated out_dict as FeatureSet
var mos = FeatureSet(Text(out_dict))
return mos
RandyBonds_Jr_
Yes! I have confirmed it's working for us as well. Thanks for the quick attention to this issue.
JessicaLott_Dymaptic
Hello!
We are starting to see this error as well. Could the bug have been reintroduced?
Thanks!
RandyBonds_Jr_
I'm not seeing it on my dashboard... it's working correctly
LJackson29
Our dashboards with data expressions are working as well.
KerryKang
my data expression seems working using 'FeatureSetByPortalItem' in the preview and editing mode, but not in the view mode. There are multiple widgets/ URL parameter working together with my data expression so I am not sure where the issue is coming from exactly.
LJackson29
@KerryKang The bug described above is specific to map image layers, so if you are using a feature service, your issue might be something different.
