AGOL Operations Dashboard
1539
01-08-2018 06:46 AM
LianaSmith
Does Operations Dashboard support layer with join? I am trying to use it, but get "can not access data"
Thank you!
by Anonymous User
Not applicable
Hi Liana,
Operations Dashboard should be able to generate server side statistics using layers that have a join. Can you check the network requests (via the browser developer tools) to see what the error code and message is?
If you still experience issues, you can reach out directly to the team at [email protected] or by opening a technical support case.
LianaSmith
Hi Aaron!
Here is what I am getting :
by Anonymous User
Not applicable
Can you open the "Network" tab, this will let you see the requests sent to your server. Then try to add the visualization using the layer that gives you an issues. You should see requests like "../FeatureServer/query". Click on one of those and then click on the "Preview" sub-tab to see the full response.
It should look something like (yours probably will have an error):
Network Requests
