Persist Widget Formatting with Arcade Expression Update
630
03-20-2025 05:50 AM
Status: Open
Labels (2)
DerekLutchko_LTC
Hi - We often use Arcade expressions to build Feature Sets as a data source for widgets. When editing and saving the expression, the widget item loses any formatting. This can be frustrating when developing a dashboard, as you'll at least partially format a widget (ie: a list, with dynamic text based on fields from the feature set), then continue to develop the rest of the dashboard, then realize you need to add or modify the expression.
I understand the feature set could change and not return what the widget was expecting in {fields} but it'd be nice if it could by default keep the formatting and only 'break' the parts that are no longer valid. It would save alot of time re-formatting lost work.
