Enable Item classification as a dynamic field
365
04-20-2026 03:11 AM
Status: Open
NiklasNorrthon1
Some of the Dashboard widgets allow for dynamic text. The most obvious example is the list widget where you can use field values embedded in static test. Some of  dynamic texts are linked to the application or the portal Item. E.g. the Item description, the item creation date, the item owner and so on.
I am missing the option to put in the item classification, along with the other item properties.
