ArcMap VBScript
1317
12-24-2018 08:25 AM
ShaningYu
Honored Contributor
I need to display Label w/ 2 fields' values like that  [_PID] & "/" & [_NAME].  Its VBScript looks like that below:
But if [_PID] == [_NAME], I only need to display [_PID].  I tried the VBScript below:
Function FindLabel ( [_PID] )
 dim newString as string
 newString = ""
 if [_PID] == [_NAME]  then
  newString = [_PID]
else
  newString = [_PID] & "/" & [_NAME]
end if
However, I receive error: "Carriage returns are not allowed in simple expressions".
How this problem can be fixed?  Thanks if you can help.
Tags (1)
ShaningYu
Honored Contributor
Changed to
Function FindLabel ( [_PID], [_NAME] )
if [_PID] <> [_NAME] then
FindLabel =  [_PID] & "/" & [_NAME]
else
FindLabel =  [_PID]
end if
end function
Then it works.  Thanks for your review.
KenBuja
MVP Esteemed Contributor
In VBScript, you'll always get an error if you instantiate a variable as a specific object like this:
You have to just do that like this:
dim newString
