Export Infographics - Community Analyst
1066
02-20-2020 12:25 AM
JonathanReger1
Hi there,
I have an issue regarding the Export-function of infographics with included maps in the Community-Analyst...
There's everything working fine with making the Infographic for a certain area...
But when I then want to export this Inforaphics into an PDF-File, the PDF looks like this:
As you see: the map is missing!
The Problem occurs also when trying to export to JPG or printing the Inforgraphics...
It all worked fine till ca. 2 weeks ago, but since then, always the same bug.
I have also tried differnt settings in the "Cange preferences Menu", like allowing to export static maps, if dynamic maps are not avaiable, but haven't found a solution yet....
Can anyone halp me with this issue?
Best Regards,
Jonathan
