Why does Collector say Update failed?
15978
22
08-01-2014 08:14 AM
JoshWhite
Honored Contributor
When I was testing Collector I made a test feature but got a message that the update failed-updates could not be sent and I can cancel or retry.  Cancel abandons the feature and retry returns the same result.
Josh White, AICP
Principal Planner
City of Arkansas City
RandyWeaver
This did solve our issue that we were having with this exact error. I am going to do more investigations as to why SQL is having a memory pressure problem and what exactly that means in regards to use of spatial types on SQL Server.
nev
I believe the underlying cause of "There are no rows in the current fetch buffer" error is archiving.  I was getting this error a lot and had to disable archiving to stop it.  Luckily i was just trialing offline and dont have a major need for it at the moment.
Would be interested to see if that fix works, not sure how taking the DB off line then back would be a long term fix though?
JoshWhite
Honored Contributor
Just an update, we are still testing out and haven't officially taken the plunge yet (yep a year later) but to the best of my knowledge this error is no longer happening and to be completely honest, I have no idea what we did to fix it anymore or if a bug fix was patched on.  I have always been in online mode, so archiving wasn't my issue and I never saw the error mentioned above.
Josh White, AICP
Principal Planner
