Why do tiled basemaps have incomplete rendering in Collector?
1548
04-17-2017 06:47 AM
ScottStopyak
Tiled basemaps have poor rendering with missing tiles that may never render. Is there a solution?
JakeSkinner
Esri Esteemed Contributor
Hi Scott,
Do these tiles appear in the web map?
ScottStopyak
Hi Jake,
The performance is far better in a web map, even using the same internet connection. In a web map, the tiles might lag a bit sometimes but all tiles will eventually render. In Collector, missing tiles may or may not ever render unless I pan and zoom around manually, quite a bit.
I’d rather not have to store basemaps on the devices, if I can help it.
DougMorgenthaler
Hi Scott-
Are these basemaps hosted by Esri?  What platform are you using Collector on in this scenario?
