webmap identify showing repetition
1351
09-16-2016 06:50 AM
AliBarakat
Hello,
i am using the webmap in the map viewer and the collector.
when i click to identify, it will show for example 10 results, and 5 of these result are the same.
is that a known issue?
thank you
JuanLuera
Hola Ali,
To answer your questions we have not seen this issue within Support Services, but I would suggest you logging a support case. We can then look to acquire some information on the issue being seen within Collector, and then look to resolve the issue being seen within Collector. Gracias, Ali!
Esri Support Home
Juan
