Viewing attribute table while in Collector
1938
04-12-2021 04:14 PM
AlfredBaldenweck
MVP Frequent Contributor
Is there a way to see the attribute table of a feature class while in Collector?
I don't mean just what I'm actively editing, but seeing the entire table.
Thanks!
RandyBurton
When you design the pop-up for the map, under configure attributes, you can select all the attributes you want to display.  You can also select those attributes that can be edited. These are two separate check-boxes.  When a field user selects a feature, all the attributes that have been selected to display will be shown (editable and non-editable).  When editing is selected then only those attributes where editing has been enabled will be shown.  However, it is not possible to see all (editable and non-editable) attributes in edit mode.
AlfredBaldenweck
Sorry, I should have been more clear.
I'm looking for a way to view every record in the table, not just one at a time.
The reason for this is to help us keep track of our numbering more easily; it's easier to catch and fix two Feature_036s in the field than it is in the office.
