Unable to add feature while using own Basemap
1741
03-24-2014 04:58 AM
BrianVillers
I have recently added several of my own basemaps to an android device.  However, when I go to collect new features, I receive the following error "Unable to add feature".
[ATTACH=CONFIG]32433[/ATTACH]
Brian
RussRoberts
Esri Notable Contributor
Are you trying to add a feature that could be outside the extent of data that you downloaded?
Thanks
Russ
BrianVillers
No I have been trying to add features directly within the center of the basemap just to test out the functionality.  I am unable to add a feature with my own basemap within the map, but if I download the map again(if the download works) with an esri basemap I am able to add points without issue.
Thanks
Brian
RussRoberts
Can you share your service and I can look into what the issue is.
Thanks
Russ
BrianVillers
I removed the basemap layer from the device, re-added the tile package for the basemap back to the device, downloaded the map again, and now it has been working fine.  Not sure what the prior issue was ( probably user error;)) Thanks for the quick responses, will keep you posted if the issues arises again.
Thanks
Brian
