Required Fields
1039
03-04-2014 09:01 AM
EricLink
I'm sure there is a way but I would like to make only certain fields required and other ones not required.  Can someone help me out with the workflow for this?  I would really appreciate it.  I'm wondering if it is when you create your fields in the feature data set.  Thanks to all who read this.  Eric
ShaunWeston
In the current version if you've got a text field, you can set the "Allow NULL Values" field property to No and this will make the field required in collector. For domain values though it doesn't seem to work.
