Multiple Basemaps Offline
11656
15
04-04-2014 06:57 AM
KyleHeideman
Is it possible to utilize more than one basemap in an offline map?  I have two pre-loaded basemaps on a device and would like to provide a basemap switcher to users who have taken a map offline.
RussRoberts
Esri Notable Contributor
You could set the top basemap layer as an 10.2.2 ArcGIS Server tiled map service with export enabled and have it as an operational layer and then use the topo layer as a basemap layer and you can have both right now and download it as one map.
Russ
xander
Hi Russ. can you expand on this? We need an offline map showing our assets and imagery. Is it best to bake a single tpk, or can we have an offline asset tpk along with switchable offline basemap tpks?
RussRoberts
You can side load both onto the device and if they are within the same extent you can change the basemaps while offline or have one setup as a hosted service and download that with the map and have the other one side loaded and you will see it in the basemap gallery.
AdamInglis
Russ
Unfortunately we don't have server, can we do this with ArcGIS Online?
RussRoberts
Right now you cannot export tiles from a hosted service but this is something we are working on.
Russ
RobertRayner1
Thanks Russ, this is finally working and is exactly what we were looking for to overlay our assets on an imagery basemap.
Would still be good to have multiple, switchable basemaps, hopefully in the next release!
Russ
