Map Service and Feature Service in same map can't edit.
1801
08-16-2016 02:07 PM
MattTenold1
 If I add the two layers from the map service individually I can change the draw order and I can edit but I can't have labels.  If I add the root map service the labels work but I can't edit.  Anyone else have this issue?   See attachments.
JayantaPoddar
Check this Esri Article http://support.esri.com/technical-article/000012244
Think Location
