Collector // Error : Unable to create replica
1541
05-22-2019 04:36 AM
Environnement_1Lausanne
Hello,
I am trying to add a feature layer to a map on ArcGIS Online to then use the Collector app in online and offline mode.
The problematic feature layer was published from ArcGIS Pro, enabling sync and export. The exact same procedure was used to export other feature layers that work perfectly fine in Collector with the offline mode.
For the problematic feature layer, I get an error when I try to define an offline area from the Collector app. The error is the following :
5/22/19, 1:22 PM [2B86366E-A2D1-4461-86FE-35B7FEC0225E] - Error downloading map: Error Domain=com.esri.arcgis.runtime.services.error Code=500 "Unable to create replica. Please check your parameters."
Do you have any clue on how to solve this error ?
Thank you very much in advance
MarioFederis1
I receive the same error but it also notes that 'exporting domains failed'.
