Collector can't handle required fields, i.e. Nulls Not Allowed?
12724
10
02-20-2015 10:48 AM
by Anonymous User
Not applicable
When I publish a 10.3 service from ArcGIS Server and subsequently edit the service in the Collector app, the "Done" button will not be tapped if the field is required.  But if I change the field in Catalog to allow Null values, the "Done" button in the collector app will work.
Is this a known limitation, is there a workaround, or is it a bug?
Thanks!
PaulLohr
I think Paul's mention of Update Layer Definition is explained in this document:
https://blogs.esri.com/esri/arcgis/files/2014/10/How-to-Update-Hosted-Feature-Service-Schemas1.pdf
Pretty sure this can be done on hosted feature services or local ArcGIS Server instances.
Paul Lohr
Lohr Geospatial Services, Inc.
