Collector - Auto Timeout
4567
07-31-2015 08:04 AM
BenGrod
Can you set up or customize Collector to timeout automatically when a user doesn't interact with the app after a given time? I noticed that once logged in Collector will stay logged in forever it seems, I tested it for 24 hours successfully so I'm assuming it doesn't time out at all. I recognize the offline benefits of not timing out but I also wonder for security reasons if you can define a timeout time. Any help is appreciated, thanks! We are using Collector 10.3.1 on iOS Build 990 and Portal for ArcGIS 10.3.1.
MiaogengZhang
No, we don't have this. BTW, in Android 5.0, you can have multiple user account. It might be useful to you.
MiaogengZhang
One option could be to check out Mobile device/application management solution.
BenGrod
Thank you for the suggestion Miaogeng, I will look into this. So just for clarification, there is no auto-timeout/log out on Collector?
MiaogengZhang
BenGrod
Miaogeng, thanks for the clarification and note about Android 5.0, this is very helpful!
