Can multiple vector tile packages be viewed at the same time in Collector?
1023
12-27-2018 02:59 PM
by Anonymous User
Not applicable
In ArcGIS Pro it is possible to view multiple vector tile packages (vtpk) at the same time, overlaying each other, for example; landuse polygons with contour lines on top, each from different tile packages.
Is this same functionality available in Collector?
MarkBockenhauer
Collector allows for using one VTPK as a basemap, it doesn't support viewing multiple VTPKs in the same map.   You can put all of your layers into one VTPK or create a Vector Tile Service (extractable) and take them offline.
